주요 콘텐츠로 건너뛰기
HP 15-g029wm Screen Replacement
필요한 것
  1. HP 15-g029wm Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Screen Replacement: 2 단계, 이미지 1/1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Screen Replacement: 3 단계, 이미지 1/3 HP 15-g029wm Screen Replacement: 3 단계, 이미지 2/3 HP 15-g029wm Screen Replacement: 3 단계, 이미지 3/3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Screen Replacement: 4 단계, 이미지 1/3 HP 15-g029wm Screen Replacement: 4 단계, 이미지 2/3 HP 15-g029wm Screen Replacement: 4 단계, 이미지 3/3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
  5. HP 15-g029wm Screen Replacement, Screen: 5 단계, 이미지 1/1
    • Open the laptop lid.
  6. HP 15-g029wm Screen Replacement: 6 단계, 이미지 1/2 HP 15-g029wm Screen Replacement: 6 단계, 이미지 2/2
    • Insert an opening pick beneath the display bezel.
    • While periodically prying, slide the opening pick around the perimeter of the bezel to sever the adhesive.
  7. HP 15-g029wm Screen Replacement: 7 단계, 이미지 1/1
    • Once the majority of the adhesive is severed, use an opening pick or your hands to fully remove the bezel.
  8. HP 15-g029wm Screen Replacement: 8 단계, 이미지 1/2 HP 15-g029wm Screen Replacement: 8 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the four 4 mm screws that secure the LCD panel.
  9. HP 15-g029wm Screen Replacement: 9 단계, 이미지 1/1
    • Use your hands to carefully remove/lift the panel away from the device.
    • The screen is connected to the device by a cord-do NOT pull it completely away or you risk damaging the device.
  10. HP 15-g029wm Screen Replacement: 10 단계, 이미지 1/2 HP 15-g029wm Screen Replacement: 10 단계, 이미지 2/2
    • Gently peel up the tape over the display cable.
    • If there is a hinge, flip it up.
    • Remove the display cable.
결론
Lawrence Bailey
회원 가입일: 01/29/24
205 평판
안내서 2개 작성하였습니다
Austin Community College, Team 18-2, Watkins Spring 2024 Austin Community College, Team 18-2, Watkins Spring 2024 회원
AUSTINCC-WATKINS-S24S18G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 78
