주요 콘텐츠로 건너뛰기
HP 15-r137wm TouchSmart Audio Speakers Replacement
필요한 것
  1. HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: 1 단계, 이미지 1/3 HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: 1 단계, 이미지 2/3 HP 15-r137wm TouchSmart Audio Speakers Replacement, Front Panel Assembly: 1 단계, 이미지 3/3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Audio Speakers Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Audio Speakers Replacement: 3 단계, 이미지 1/1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Audio Speakers Replacement: 4 단계, 이미지 1/2 HP 15-r137wm TouchSmart Audio Speakers Replacement: 4 단계, 이미지 2/2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Audio Speakers Replacement, Keyboard: 5 단계, 이미지 1/2 HP 15-r137wm TouchSmart Audio Speakers Replacement, Keyboard: 5 단계, 이미지 2/2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Audio Speakers Replacement: 6 단계, 이미지 1/2 HP 15-r137wm TouchSmart Audio Speakers Replacement: 6 단계, 이미지 2/2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Audio Speakers Replacement, Audio Speakers: 7 단계, 이미지 1/2 HP 15-r137wm TouchSmart Audio Speakers Replacement, Audio Speakers: 7 단계, 이미지 2/2
    • Remove the four (4) 2.5 mm Phillips #0 screws.
  8. HP 15-r137wm TouchSmart Audio Speakers Replacement: 8 단계, 이미지 1/2 HP 15-r137wm TouchSmart Audio Speakers Replacement: 8 단계, 이미지 2/2
    • Disconnect the power source from the motherboard.
    • The wires are very small and thin, so be careful when removing.
    • Lift the speakers away from the housing by sliding them out from under the motherboard.
결론
Ross B Jacques
회원 가입일: 10/18/17
857 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S4-G4, Julie Fall 2017 UMass Dartmouth, Team S4-G4, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 258
