소개
You can use this guide to help you safely and effectively remove the screen from your HP 15-r137wm TouchSmart device.
필요한 것
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
