주요 콘텐츠로 건너뛰기
HP 15-r137wm TouchSmart Screen Replacement
필요한 것
  1. HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: 1 단계, 이미지 1/3 HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: 1 단계, 이미지 2/3 HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: 1 단계, 이미지 3/3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Screen Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Screen Replacement: 3 단계, 이미지 1/1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Screen Replacement: 4 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement: 4 단계, 이미지 2/2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Screen Replacement, Keyboard: 5 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement, Keyboard: 5 단계, 이미지 2/2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Screen Replacement: 6 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement: 6 단계, 이미지 2/2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Screen Replacement, CD Drive: 7 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement, CD Drive: 7 단계, 이미지 2/2
    • Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
  8. HP 15-r137wm TouchSmart Screen Replacement, Cooling Fan: 8 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement, Cooling Fan: 8 단계, 이미지 2/2
    • Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
    • Slowly disconnect the cable as the wires are very small and fragile
  9. HP 15-r137wm TouchSmart Screen Replacement: 9 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement: 9 단계, 이미지 2/2
    • Remove the three (3) 2.5mm by 3.5mm Phillips #0 screws from the fan.
  10. HP 15-r137wm TouchSmart Screen Replacement: 10 단계, 이미지 1/1
    • Remove the cooling fan from the housing carefully.
    • The fan may be connected to the small foam screen. Pull gently to release it.
  11. HP 15-r137wm TouchSmart Screen Replacement, Screen: 11 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement, Screen: 11 단계, 이미지 2/2
    • Remove the 5.5mm Phillips #0 screw.
  12. HP 15-r137wm TouchSmart Screen Replacement: 12 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement: 12 단계, 이미지 2/2
    • Gently pull and slide the video card out of its connector.
  13. HP 15-r137wm TouchSmart Screen Replacement: 13 단계, 이미지 1/2 HP 15-r137wm TouchSmart Screen Replacement: 13 단계, 이미지 2/2
    • Lift up tape, and then remove the power cable from its connector.
  14. HP 15-r137wm TouchSmart Screen Replacement: 14 단계, 이미지 1/3 HP 15-r137wm TouchSmart Screen Replacement: 14 단계, 이미지 2/3 HP 15-r137wm TouchSmart Screen Replacement: 14 단계, 이미지 3/3
    • Remove all four (4) 5.5mm Phillips #0 screws.
    • Remove the one (1) 2.5mm Phillips #0 screw.
    • Since all of the screws are now removed, the screen will begin to fall off on its own. make sure the screen is supported before removal.
  15. HP 15-r137wm TouchSmart Screen Replacement: 15 단계, 이미지 1/1
    • The screen can now be lifted out of place from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ross B Jacques
회원 가입일: 10/18/17
881 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S4-G4, Julie Fall 2017 UMass Dartmouth, Team S4-G4, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 669
