주요 콘텐츠로 건너뛰기
소개
Use this guide to replace the hard drive in your HP 17-bs049dx.
부품
지정된 부품이 없습니다.
  1. To remove the battery, simply push the tabs towards each other.
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. Pull outwards on the disk reader to remove from main frame. This removal will require force.
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  6. Lift back panel to access internal components.
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  7. Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  8. Lift rubber black tabs located on the hard drive upwards. Disconnect hard drive from motherboard by pulling towards you.
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Logan McCarty
회원 가입일: 2018년 10월 01일
196 평판
안내서 2개 작성하였습니다
This was SPOT ON! After searching high and low all over the fricken INTERWEBS for a decent manual, I landed here on your guide and am VERY thankful! KUDOS to you for sharing it!
John Hart - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 62
전체 시간: 418
