주요 콘텐츠로 건너뛰기
HP 17-bs049dx Motherboard Replacement
필요한 것
  1. HP 17-bs049dx Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  2. HP 17-bs049dx Motherboard Replacement: 2 단계, 이미지 1/1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  3. HP 17-bs049dx Motherboard Replacement: 3 단계, 이미지 1/2 HP 17-bs049dx Motherboard Replacement: 3 단계, 이미지 2/2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  4. HP 17-bs049dx Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  5. HP 17-bs049dx Motherboard Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  6. HP 17-bs049dx Motherboard Replacement: 6 단계, 이미지 1/2 HP 17-bs049dx Motherboard Replacement: 6 단계, 이미지 2/2
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
  7. HP 17-bs049dx Motherboard Replacement, Motherboard: 7 단계, 이미지 1/3 HP 17-bs049dx Motherboard Replacement, Motherboard: 7 단계, 이미지 2/3 HP 17-bs049dx Motherboard Replacement, Motherboard: 7 단계, 이미지 3/3
    • Make sure to unplug everything connected to the motherboard.
    • Be gentle with this step.
  8. HP 17-bs049dx Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the screws (7.51mm) with a Phillips #0 screwdriver.
    • Once all of the screws are removed, remove the motherboard from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chanceline Mbiaoh
회원 가입일: 09/26/18
207 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 801
