메인 콘텐츠로 스킵하기
소개
The RAM is an extremely fast type of computer memory which temporarily stores all information of your PC needs now and in the near future. If your computer is running very slow or installing things fail multiple times, then you may have RAM damage. This guide will show you steps to replacing the RAM.
부품
지정된 부품이 없습니다.
  1. To remove the battery, simply push the tabs towards each other.
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. Pull outwards on the disk reader to remove from main frame. This removal will require force.
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. Lift back panel to access internal components.
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. To take off the RAM, pull out the circled taps in the direction of the arrows on the pictures. You will have to gently force it out to avoid breaking it.
    • To take off the RAM, pull out the circled taps in the direction of the arrows on the pictures.
    • You will have to gently force it out to avoid breaking it.
결론
Megan Paige
회원 가입일: 2018년 09월 26일
250 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 82
