주요 콘텐츠로 건너뛰기
HP 17-x027ds Hard Drive Replacement
필요한 것
  1. HP 17-x027ds Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 HP 17-x027ds Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 HP 17-x027ds Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top of the laptop.
    • Remove the battery by pulling it out.
  2. HP 17-x027ds Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/3 HP 17-x027ds Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/3 HP 17-x027ds Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3/3
    • Remove the two pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
    • When removing the two black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling.
    • Remove the fourteen 7mm JIS #1 screws.
  3. HP 17-x027ds Hard Drive Replacement: 3 단계, 이미지 1/2 HP 17-x027ds Hard Drive Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around.
    • The cover is difficult to lift, so use extreme force.
  4. HP 17-x027ds Hard Drive Replacement: 4 단계, 이미지 1/3 HP 17-x027ds Hard Drive Replacement: 4 단계, 이미지 2/3 HP 17-x027ds Hard Drive Replacement: 4 단계, 이미지 3/3
    • Disconnect the blue ends of the white ribbon cable by pulling the blue ends out of the connector.
    • The ribbon cable will still be connected to the rubber and just the ends will be disconnected.
  5. HP 17-x027ds Hard Drive Replacement: 5 단계, 이미지 1/2 HP 17-x027ds Hard Drive Replacement: 5 단계, 이미지 2/2
    • Lift the black rubber cover containing the hard drive by lifting the right side of the rubber cover.
    • The white ribbon cable will still be connected to the rubber cover, so remove the hard drive out from under.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bill Hoang
회원 가입일: 09/18/18
452 평판
안내서 2개 작성하였습니다
University of North Texas, Team S3-G1, Raign Fall 2018 University of North Texas, Team S3-G1, Raign Fall 2018 회원
UNT-RAIGN-F18S3G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,065
