소개
This guide will assist you in replacing the HP LCD Screen. You will need to replace the screen if your screen displays black and white lines over your homepage.
필요한 것
Open the laptop so you can see the screen.
Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
