주요 콘텐츠로 건너뛰기
HP 17-x061nr Hard Drive Replacement
필요한 것
  1. HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: 1 단계, 이미지 1/3 HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: 1 단계, 이미지 2/3 HP 17-x061nr Hard Drive Replacement, HP 17-x061nr  Disassembly: 1 단계, 이미지 3/3
    • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
  2. HP 17-x061nr Hard Drive Replacement: 2 단계, 이미지 1/2 HP 17-x061nr Hard Drive Replacement: 2 단계, 이미지 2/2
    • Peel back the rubber footrests located next to the battery, on the left and right sides.
    • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
  3. HP 17-x061nr Hard Drive Replacement: 3 단계, 이미지 1/1
    • Slide the optical drive out and away from the laptop.
  4. HP 17-x061nr Hard Drive Replacement: 4 단계, 이미지 1/3 HP 17-x061nr Hard Drive Replacement: 4 단계, 이미지 2/3 HP 17-x061nr Hard Drive Replacement: 4 단계, 이미지 3/3
    • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
    • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
    • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
  5. HP 17-x061nr Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Locate the hard drive.
    • Using the purple hard plastic tab gently pull the cable tape tab out of the input, located on the left-hand side.
  6. HP 17-x061nr Hard Drive Replacement: 6 단계, 이미지 1/2 HP 17-x061nr Hard Drive Replacement: 6 단계, 이미지 2/2
    • Carefully peel back the cable tape from the hard drive itself.
    • Pull the shock absorbers from the back of the hard drive casing.
  7. HP 17-x061nr Hard Drive Replacement: 7 단계, 이미지 1/1
    • Lift up the back of the hard drive module and gently pull it away from the connection point.
    • Be sure to keep the replacement within the package until you are ready to place it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Curtis Haley
회원 가입일: 02/23/18
514 평판
안내서 3개 작성하였습니다
Washington State, Team S1-G1, Lobnitz Spring 2018 Washington State, Team S1-G1, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S1G1
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Will this work for HP Notebook - 17-y018ca
hamiltoncomputes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 1,787
