주요 콘텐츠로 건너뛰기
HP 17-x116dx Space bar key Replacement
필요한 것
  1. HP 17-x116dx Space bar key Replacement, Space Bar Key: 1 단계, 이미지 1/1
    • Locate the spacebar key.
  2. HP 17-x116dx Space bar key Replacement: 2 단계, 이미지 1/1
    • At the edge of the space bay key use a spudger to help with the removal.
  3. HP 17-x116dx Space bar key Replacement: 3 단계, 이미지 1/1
    • Slide the spudger under the spacebar key.
  4. HP 17-x116dx Space bar key Replacement: 4 단계, 이미지 1/1
    • The left side of the spacebar key will start lifting up. At this point you can remove the spacebar key.
  5. HP 17-x116dx Space bar key Replacement: 5 단계, 이미지 1/1
    • During this point you can carefully take off the spacebar key.
  6. HP 17-x116dx Space bar key Replacement: 6 단계, 이미지 1/1
    • you will notice a metal bars along the rim these metal bars is what connects the bottom surface together.
  7. HP 17-x116dx Space bar key Replacement: 7 단계, 이미지 1/1
    • Dust off any dirt that could be under there.
  8. HP 17-x116dx Space bar key Replacement: 8 단계, 이미지 1/1
    • The lower edge of the keyboard has two plastic notches on either side.
  9. HP 17-x116dx Space bar key Replacement: 9 단계, 이미지 1/1
    • slide the bracket into the space below the spacebar to carefully place it back.
  10. HP 17-x116dx Space bar key Replacement: 10 단계, 이미지 1/1
    • The Spacebar key will be working once you can press down and it will type a space.
결론
Liliana Chuc
회원 가입일: 03/22/18
281 평판
안내서 1개 작성함
Sam Houston State, Team S17-G1, Blackburne Spring 2018 Sam Houston State, Team S17-G1, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 940
