주요 콘텐츠로 건너뛰기
HP 17-x173dx CPU Cooling Fan Replacement
필요한 것
  1. HP 17-x173dx CPU Cooling Fan Replacement, Battery: 1 단계, 이미지 1/2 HP 17-x173dx CPU Cooling Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Begin by sliding the left tab to the unlock position
  2. HP 17-x173dx CPU Cooling Fan Replacement: 2 단계, 이미지 1/1
    • Push each of the two tabs in the direction specified by the picture.
  3. HP 17-x173dx CPU Cooling Fan Replacement: 3 단계, 이미지 1/3 HP 17-x173dx CPU Cooling Fan Replacement: 3 단계, 이미지 2/3 HP 17-x173dx CPU Cooling Fan Replacement: 3 단계, 이미지 3/3
    • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
  4. HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: 4 단계, 이미지 1/2 HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: 4 단계, 이미지 2/2
    • Use a spudger or Jimmy to lift the plastic back cover starting from the back right side near the vents.
    • Remove the back cover of the device by continuing to lift the plastic around the entire perimeter of the device.
  5. HP 17-x173dx CPU Cooling Fan Replacement: 5 단계, 이미지 1/3 HP 17-x173dx CPU Cooling Fan Replacement: 5 단계, 이미지 2/3 HP 17-x173dx CPU Cooling Fan Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, unscrew four heat-sink screws (These will unscrew, but will stay attached to the heat-sink), and one screw towards the top.
    • Disconnect the power cable.
  6. HP 17-x173dx CPU Cooling Fan Replacement: 6 단계, 이미지 1/2 HP 17-x173dx CPU Cooling Fan Replacement: 6 단계, 이미지 2/2
    • Remove the CPU cooling fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katelyn Tomlin
회원 가입일: 09/16/19
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 380
