주요 콘텐츠로 건너뛰기
HP 2000 - 2D22DX Hard Drive Replacement
필요한 것
  1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP 2000 - 2D22DX Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Hard Drive Replacement: 2 단계, 이미지 1/2 HP 2000 - 2D22DX Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Loosen the Phillips #00 screw securing the RAM compartment cover.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX Hard Drive Replacement: 4 단계, 이미지 1/2 HP 2000 - 2D22DX Hard Drive Replacement: 4 단계, 이미지 2/2
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Hard Drive Replacement: 5 단계, 이미지 1/3 HP 2000 - 2D22DX Hard Drive Replacement: 5 단계, 이미지 2/3 HP 2000 - 2D22DX Hard Drive Replacement: 5 단계, 이미지 3/3
    • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
    • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
    • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  6. HP 2000 - 2D22DX Hard Drive Replacement: 6 단계, 이미지 1/3 HP 2000 - 2D22DX Hard Drive Replacement: 6 단계, 이미지 2/3 HP 2000 - 2D22DX Hard Drive Replacement: 6 단계, 이미지 3/3
    • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
  7. HP 2000 - 2D22DX Hard Drive Replacement: 7 단계, 이미지 1/3 HP 2000 - 2D22DX Hard Drive Replacement: 7 단계, 이미지 2/3 HP 2000 - 2D22DX Hard Drive Replacement: 7 단계, 이미지 3/3
    • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
    • Lift the hard drive out and away from its socket in the plastic chassis.
결론
다른 27명이 해당 안내서를 완성하였습니다.
Conor Most
회원 가입일: 04/14/14
2,687 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 회원
CPSU-MANESS-S14S3G40
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 30
전체 시간: 14,565
