주요 콘텐츠로 건너뛰기
HP 2000-2d19wm Keyboard Replacement
필요한 것
  1. HP 2000-2d19wm Keyboard  Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP 2000-2d19wm Keyboard  Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • First make sure you have a clear work space
    • Make sure you have all of the tools to do this job! If not you may break something else doing this Repair
    • Not all the tools in the picture I needed.
  2. HP 2000-2d19wm Keyboard  Replacement: 2 단계, 이미지 1개 중 1개
    • My keyboard is kind of bad so the general idea is to get a flat bladed screwdriver under Neath of the old keyboard not the keys it may help if you take all of the old keys off around the sides
  3. HP 2000-2d19wm Keyboard  Replacement: 3 단계, 이미지 2개 중 1개 HP 2000-2d19wm Keyboard  Replacement: 3 단계, 이미지 2개 중 2개
    • pry Up on the old keyboard until you see the 5 pins pop up out of place once all 5 come undone the old key board should come right out
  4. HP 2000-2d19wm Keyboard  Replacement: 4 단계, 이미지 1개 중 1개
    • Now the old keyboard is out.
  5. HP 2000-2d19wm Keyboard  Replacement: 5 단계, 이미지 3개 중 1개 HP 2000-2d19wm Keyboard  Replacement: 5 단계, 이미지 3개 중 2개 HP 2000-2d19wm Keyboard  Replacement: 5 단계, 이미지 3개 중 3개
    • Put the pins of the new keyboard in then put it back into place as the old one was.
  6. HP 2000-2d19wm Keyboard  Replacement: 6 단계, 이미지 1개 중 1개
    • That’s the end your laptop should be working just right now one thing I forgot to mention was you had to plug the cable on the keyboard back in if you did not do so your keyboard definitely will not work.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walker wallace
회원 가입일: 11/01/16
975 평판
안내서 3개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,454개를 작성함
2가이드 댓글
The keyboard you totally destroyed which was not required. You undo the screw on the bottom under the door, and then use the pins at the top of the keyboard which then the keyboard will come up slightly where you can get under it and pry gently along the top, and then sides… After that the keyboard pulls right out and you undo the ribbon cable…
You murdered that keyboard… If you are going to create instructions for others to follow, please make sure you know what your doing to begin with… So no one follows your poor example
Dennis - 답글
Sorry but it’s not my fault it was the first time I worked on one I don’t know everything yet I’m only 17 and I’m learning as I go
Walker wallace - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 23
전체 시간: 616
