주요 콘텐츠로 건너뛰기
HP 310-1037 Motherboard Replacement
필요한 것
  1. HP 310-1037 Motherboard Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 HP 310-1037 Motherboard Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 HP 310-1037 Motherboard Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
    • Lay the PC flat on the front to gain access to the stand cover
    • Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
  2. HP 310-1037 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 HP 310-1037 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 HP 310-1037 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the stand cover
    • The hard drive caddy is held in place with 1 Phillips screw
    • Use a #0 Phillips screwdriver to remove that screw
  3. HP 310-1037 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HP 310-1037 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HP 310-1037 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the handle on the hard drive caddy
    • and pull it to the backside. This will remove the hard drive caddy from the computer.
    • To remove the hard drive from the caddy, turn it over. There are four Phillips scres that hold the hard drive in place.
  4. HP 310-1037 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HP 310-1037 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Once the four screws are removed, slide the hard drive out of the caddy.
    • Here is the failed drive. It is a Hitachi HDS721010CLA332. Failure with this drive is all to common.
  5. HP 310-1037 Motherboard Replacement, Remove stand: 5 단계, 이미지 1개 중 1개
    • Remove the four Torx/Flathead screws securing the stand.
    • Lift the bottom part of the stand upwards, and it will come off.
  6. HP 310-1037 Motherboard Replacement, Remove back cover: 6 단계, 이미지 1개 중 1개
    • Remove the four Torx/Flathead screws securing the back cover.
    • Also unscrew the two captive Philips screws securing the disc drive, as these two screws also secure the back cover.
  7. HP 310-1037 Motherboard Replacement, Remove metal shield: 7 단계, 이미지 1개 중 1개
    • Remove the seven silver Torx/Flathead screws securing the metal shield.
    • Remove the single black Torx/Flathead screw securing the metal shield.
    • Remove the cables strung through the shield.
    • Pull up on the shield to remove it.
  8. HP 310-1037 Motherboard Replacement, Remove fan: 8 단계, 이미지 1개 중 1개
    • Remove the two Torx/Flathead screws securing the fan.
    • Pull up on the fan connector to remove it.
    • Lift the fan to remove it.
  9. HP 310-1037 Motherboard Replacement, Remove heatsink assembly: 9 단계, 이미지 1개 중 1개
    • Remove the six Philips screws securing the heatsink assembly to the motherboard.
    • Carefully lift the heatsink. If it won't come off, twist it as you pull it off. If it still won't come off, pull harder.
    • Unfortunately, if you have to resort to pulling harder, the processor will likely come off with the heatsink. If this happens, use an adjustable heat gun set to ~200C to soften the thermal paste, first.
  10. HP 310-1037 Motherboard Replacement, Remove motherboard: 10 단계, 이미지 1개 중 1개
    • Remove all attached connectors from the motherboard.
    • Remove the four remaining screws securing the motherboard. You're done!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Joseph Sctbunio
회원 가입일: 09/23/17
7,527 평판
안내서 42개를 작성함
댓글 한 개
How do u take the DVD drive out?
Sam's Tech Review - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 19
전체 시간: 2,212
