소개
You will be disassembling the HP 7 1800 and using a soldering iron to replace the audio jack.
필요한 것
Use a Spudger to open the back panel. Be careful not to break the tabs.
Once the solder is removed, gently pull the audio jack away from the motherboard with tweezers.
거의 끝나갑니다!
결론
