소개
This guide will help you replace the battery in your HP 7 1800 in a fast and safe manner. You will need a Spudger to open the case to get inside to the battery.
부품
No parts specified.
  1. Carefully insert a Spudger into one of the corners of the tablet. Slide the Spudger along the edge popping the tabs out along the way.
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  3. Slide the Spudger under the battery to lift it off the adhesive. Gently pull the cable connection from the motherboard using tweezers. Gently pull the cable connection from the motherboard using tweezers.
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Todd Dobrozdravic
회원 가입일: 2015년 01월 21일
765 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 회원
USFT-BROWN-W15S4G1
4 회원들
안내서 14개 작성하였습니다
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - 답글
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 22
전체 시간: 2,639
