주요 콘텐츠로 건너뛰기
HP 7 1800 Battery Replacement
필요한 것
  1. HP 7 1800 Battery Replacement, Remove the back panel: 1 단계, 이미지 1/2 HP 7 1800 Battery Replacement, Remove the back panel: 1 단계, 이미지 2/2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Battery Replacement, Remove the battery: 2 단계, 이미지 1/3 HP 7 1800 Battery Replacement, Remove the battery: 2 단계, 이미지 2/3 HP 7 1800 Battery Replacement, Remove the battery: 2 단계, 이미지 3/3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
TMD
회원 가입일: 01/21/15
765 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 회원
USFT-BROWN-W15S4G1
4 회원들
안내서 14개 작성하였습니다
댓글 2개
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - 답글
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 3,322
