메인 콘텐츠로 스킵하기
소개
This guide requires you to take apart nearly the entire tablet to get to the display. Be sure to keep track of the screws.
  1. Carefully insert a Spudger into one of the corners of the tablet. Slide the Spudger along the edge popping the tabs out along the way.
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. Slide the Spudger under the battery to lift it off the adhesive. Gently pull the cable connection from the motherboard using tweezers. Gently pull the cable connection from the motherboard using tweezers.
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers. Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers. Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  6. Remove the following  7 screws:
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  7. Gently pry the front facing camera plug up and off of the motherboard.
    • Gently pry the front facing camera plug up and off of the motherboard.
  8. Carefully lift the motherboard directly up.
    • Carefully lift the motherboard directly up.
  9. On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out. On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
    • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
  10. Unscrew the following black screws:
    • Unscrew the following black screws:
    • Seven 2.82mm Phillips #00 around the metal casing.
  11. Gently lift the metal plate directly up.
    • Gently lift the metal plate directly up.
  12. Gently lift the display directly up.
    • Gently lift the display directly up.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Todd Dobrozdravic
회원 가입일: 2015년 01월 21일
765 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 회원
USFT-BROWN-W15S4G1
4 회원들
안내서 14개 작성하였습니다
I have this same tablet but I cannot find a replacement screen. Do you know where I could find one?
Karen Porter - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 1,548
