주요 콘텐츠로 건너뛰기
HP 7 1800 Motherboard Replacement
필요한 것
  1. HP 7 1800 Motherboard Replacement, Remove the back panel: 1 단계, 이미지 1/2 HP 7 1800 Motherboard Replacement, Remove the back panel: 1 단계, 이미지 2/2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Motherboard Replacement, Remove the battery: 2 단계, 이미지 1/3 HP 7 1800 Motherboard Replacement, Remove the battery: 2 단계, 이미지 2/3 HP 7 1800 Motherboard Replacement, Remove the battery: 2 단계, 이미지 3/3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: 3 단계, 이미지 1/2 HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: 3 단계, 이미지 2/2
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: 4 단계, 이미지 1/2 HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: 4 단계, 이미지 2/2
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: 5 단계, 이미지 1/1
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: 6 단계, 이미지 1/1
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Motherboard Replacement, Remove the logic board: 7 단계, 이미지 1/1
    • Carefully lift the motherboard directly up.
결론
TMD
회원 가입일: 01/21/15
765 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 회원
USFT-BROWN-W15S4G1
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 925
