주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The motherboard could be the root of many problems of your HP 7 1800. This guide will aid you in replacing the motherboard.
부품
지정된 부품이 없습니다.
  1. Carefully insert a Spudger into one of the corners of the tablet. Slide the Spudger along the edge popping the tabs out along the way.
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. Slide the Spudger under the battery to lift it off the adhesive. Gently pull the cable connection from the motherboard using tweezers. Gently pull the cable connection from the motherboard using tweezers.
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers. Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  5. Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers. Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  6. Remove the following  7 screws:
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  7. Gently pry the front facing camera plug up and off of the motherboard.
    • Gently pry the front facing camera plug up and off of the motherboard.
  8. Carefully lift the motherboard directly up.
    • Carefully lift the motherboard directly up.
결론
Todd Dobrozdravic
회원 가입일: 2015년 01월 21일
765 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 회원
USFT-BROWN-W15S4G1
4 회원들
안내서 14개 작성하였습니다
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 719
