소개
This guide will help you replace the power and volume buttons on your HP 7 1800.
필요한 것
Use a Spudger to open the back panel. Be careful not to break the tabs.
The power button and volume buttons are together as a single piece. Gently pull up on one side and then pull up on the other side to remove the buttons from the casing.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
