주요 콘텐츠로 건너뛰기
HP 7 1800 Speaker Replacement
필요한 것
  1. HP 7 1800 Speaker Replacement, Remove the back panel: 1 단계, 이미지 1/2 HP 7 1800 Speaker Replacement, Remove the back panel: 1 단계, 이미지 2/2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Speaker Replacement, Remove the battery: 2 단계, 이미지 1/3 HP 7 1800 Speaker Replacement, Remove the battery: 2 단계, 이미지 2/3 HP 7 1800 Speaker Replacement, Remove the battery: 2 단계, 이미지 3/3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Speaker Replacement, Desolder the speaker wires: 3 단계, 이미지 1/1
    • Desolder the two leads of the speaker wire that are connected to the motherboard.
  4. HP 7 1800 Speaker Replacement, Remove the speaker: 4 단계, 이미지 1/1
    • Using tweezers, gently pull the speaker off of the metal plate.
    • The speaker is held onto the metal plate with light adhesive. It will require a little force to peel off.
결론
TMD
회원 가입일: 01/21/15
765 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 회원
USFT-BROWN-W15S4G1
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 203
