소개
The battery might need to be changed if the device does not power up, or does not charge anymore. The most challenging step to changing the battery is removing the back cover. The tools listed (or similar) are necessary for the battery replacement.
필요한 것
Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
