주요 콘텐츠로 건너뛰기
HP 7 PLUS 1301 Battery Replacement
필요한 것
  1. HP 7 PLUS 1301 Battery Replacement, Battery: 1 단계, 이미지 1/2 HP 7 PLUS 1301 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the device is off and not plugged in before starting.
    • Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
  2. HP 7 PLUS 1301 Battery Replacement: 2 단계, 이미지 1/2 HP 7 PLUS 1301 Battery Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Battery Replacement: 3 단계, 이미지 1/2 HP 7 PLUS 1301 Battery Replacement: 3 단계, 이미지 2/2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Battery Replacement: 4 단계, 이미지 1/2 HP 7 PLUS 1301 Battery Replacement: 4 단계, 이미지 2/2
    • Push out the connector to disconnect the battery.
    • Move the battery connector clear of the connector socket.
  5. HP 7 PLUS 1301 Battery Replacement: 5 단계, 이미지 1/1
    • Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adanna Ilori
회원 가입일: 02/05/19
301 평판
안내서 2개 작성하였습니다
UC Davis, Team S20-G6, Lore Winter 2019 UC Davis, Team S20-G6, Lore Winter 2019 회원
UCD-LORE-W19S20G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 727
