소개
If the device's speaker isn't working, then it may be necessary to replace it. The most challenging step to replace the speaker is removing the back cover. The tools listed (or similar) are necessary to fix the speaker properly.
필요한 것
Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
