주요 콘텐츠로 건너뛰기
HP 7 Plus 1302 Back Cover Replacement
필요한 것
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: 2 단계, 이미지 1/2 HP 7 Plus 1302 Back Cover Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: 3 단계, 이미지 1/2 HP 7 Plus 1302 Back Cover Replacement: 3 단계, 이미지 2/2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
결론
Marquies
회원 가입일: 07/07/15
245 평판
안내서 1개 작성함
IUPUI, Team 1-2, Renguette SU 2015 IUPUI, Team 1-2, Renguette SU 2015 회원
IUPUI-RENGUETTE-SU15S1G2
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,017
