주요 콘텐츠로 건너뛰기
HP 7 Plus 1302 Camera Replacement
필요한 것
  1. HP 7 Plus 1302 Camera Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Camera Replacement: 2 단계, 이미지 1/2 HP 7 Plus 1302 Camera Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Camera Replacement: 3 단계, 이미지 1/2 HP 7 Plus 1302 Camera Replacement: 3 단계, 이미지 2/2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Camera Replacement, Front and Rear Facing Cameras: 4 단계, 이미지 1/1
    • The cameras are connected together via a small ribbon cable with one electrical connection in between them.
    • Locate the small grey connector near the top of the device. Using the Spudger tool, gently pull it away from the device until it releases its connection.
    • This will come out very easily so don't use much force.
  5. HP 7 Plus 1302 Camera Replacement: 5 단계, 이미지 1/2 HP 7 Plus 1302 Camera Replacement: 5 단계, 이미지 2/2
    • Next move to front facing camera. Using the plastic spudger, push the small tabs out of the way while lightly pulling up on the camera.
    • There is a tab on either side of the camera that must both be released.
    • Then gently pull the camera up and away from the device.
  6. HP 7 Plus 1302 Camera Replacement: 6 단계, 이미지 1/1
    • The rear facing camera is held down with double sided tape.
    • Using the tweezers, gently pry the rear facing camera up out of its socket.
  7. HP 7 Plus 1302 Camera Replacement: 7 단계, 이미지 1/1
    • Lift the camera assembly away from the device to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Hegg
회원 가입일: 07/09/15
224 평판
안내서 1개 작성함
IUPUI, Team 1-2, Renguette SU 2015 IUPUI, Team 1-2, Renguette SU 2015 회원
IUPUI-RENGUETTE-SU15S1G2
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 318
