소개
If the device is failing to charge it may be necessary to replace the charging port. The most difficult step will be soldering the charging port, it is important to make sure you have all tools required and follow the instructions precisely.
필요한 것
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
다른 한 분이 해당 안내서를 완성하였습니다.
