주요 콘텐츠로 건너뛰기
HP 7 Plus 1302 Motherboard Replacement
필요한 것
  1. HP 7 Plus 1302 Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 HP 7 Plus 1302 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Pull the circuit board off.
결론
작성자
5다른 기여자 명과 함께
Damaris Torres-Crespo
회원 가입일: 01/30/17
204 평판
안내서 2개를 작성함
IUPUI, Team 1-4, Baechle Spring 2017 IUPUI, Team 1-4, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S1G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 239
