주요 콘텐츠로 건너뛰기
HP 7 Plus 1302 Power and Volume Button Replacement
필요한 것
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: 2 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Power and Volume Button Replacement: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: 3 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Power and Volume Button Replacement: 3 단계, 이미지 2개 중 2개
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: 4 단계, 이미지 1개 중 1개
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: 5 단계, 이미지 2개 중 1개 HP 7 Plus 1302 Power and Volume Button Replacement: 5 단계, 이미지 2개 중 2개
    • Pop out the power and volume buttons with your hands
결론
작성자
5다른 기여자 명과 함께
Shannon Suttles
회원 가입일: 01/29/17
225 평판
안내서 2개를 작성함
IUPUI, Team 1-4, Baechle Spring 2017 IUPUI, Team 1-4, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S1G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 360
