주요 콘텐츠로 건너뛰기
HP 8 1401 Back Panel Replacement
필요한 것
  1. HP 8 1401 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Back Panel Replacement: 2 단계, 이미지 1/1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Back Panel Replacement: 3 단계, 이미지 1/2 HP 8 1401 Back Panel Replacement: 3 단계, 이미지 2/2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
결론
To reassemble your device, follow these instructions in reverse order. Align the front and back panels and press them together, then screw in the four screws.
Katie Presz
회원 가입일: 01/16/19
641 평판
안내서 6개 작성하였습니다
University of Alabama, Team S1-G1, Bedsole Spring 2019 University of Alabama, Team S1-G1, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 7
전체 시간: 223
