소개
This guide is helpful if you need to replace a dead or damaged battery. Be careful when removing the battery to not bend or puncture it because it may contain hazardous chemicals.
필요한 것
Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
이 단계에 사용된 도구:Plastic Cards$2.99
Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
거의 끝나갑니다!
결론
