소개
This guide will help you if your rear-facing camera is cracked or damaged. You may need to pull a little bit to remove the camera, it is well secured in the tablet.
필요한 것
Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
Lift the rear-facing camera out of its compartment using the tweezers.
거의 끝나갑니다!
결론
