주요 콘텐츠로 건너뛰기
HP Beats Special Edition 15-p390nr Fan Replacement
필요한 것
  1. HP Beats Special Edition 15-p390nr Fan Replacement, Keyboard: 1 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Fan Replacement, Keyboard: 1 단계, 이미지 2/2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Fan Replacement: 2 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Fan Replacement: 2 단계, 이미지 2/2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Fan Replacement: 3 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Fan Replacement: 3 단계, 이미지 2/2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Fan Replacement: 4 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Fan Replacement: 4 단계, 이미지 2/2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Fan Replacement: 5 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Fan Replacement: 5 단계, 이미지 2/2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Fan Replacement: 6 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Fan Replacement: 6 단계, 이미지 2/2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr Fan Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. HP Beats Special Edition 15-p390nr Fan Replacement: 8 단계, 이미지 1/1
    • Unclamp wire strips from motherboard.
  9. HP Beats Special Edition 15-p390nr Fan Replacement: 9 단계, 이미지 1/1
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. HP Beats Special Edition 15-p390nr Fan Replacement: 10 단계, 이미지 1/1
    • Unclip wifi card for further procedures
  11. HP Beats Special Edition 15-p390nr Fan Replacement, Fan: 11 단계, 이미지 1/1
    • Remove the fan cable from the connector that connects to the motherboard.
    • Pull straight out to avoid damage to connectors.
  12. HP Beats Special Edition 15-p390nr Fan Replacement: 12 단계, 이미지 1/1
    • Remove all three screws that hold the fan to the system board
  13. HP Beats Special Edition 15-p390nr Fan Replacement: 13 단계, 이미지 1/1
    • Lift and remove the fan from the top cover.
결론
Evan Rice
회원 가입일: 10/02/18
506 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 20
전체 시간: 2,645
