주요 콘텐츠로 건너뛰기
HP Beats Special Edition 15-p390nr Motherboard Replacement
필요한 것
  1. HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: 1 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Motherboard Replacement: 2 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Motherboard Replacement: 2 단계, 이미지 2/2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Motherboard Replacement: 3 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Motherboard Replacement: 3 단계, 이미지 2/2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Motherboard Replacement: 4 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Motherboard Replacement: 5 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Motherboard Replacement: 5 단계, 이미지 2/2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Motherboard Replacement: 6 단계, 이미지 1/2 HP Beats Special Edition 15-p390nr Motherboard Replacement: 6 단계, 이미지 2/2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. HP Beats Special Edition 15-p390nr Motherboard Replacement: 8 단계, 이미지 1/1
    • Unclamp wire strips from motherboard.
  9. HP Beats Special Edition 15-p390nr Motherboard Replacement: 9 단계, 이미지 1/1
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. HP Beats Special Edition 15-p390nr Motherboard Replacement: 10 단계, 이미지 1/1
    • Unclip wifi card for further procedures
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michelle
회원 가입일: 10/02/18
115 평판
안내서 1개 작성함
댓글 4개
Please where can i buy the motherboard ?
Nelson - 답글
Please, where can i buy a new motherboard for this laptop ? Thank you
Nelson - 답글
What does it mean if it beeps twice and doesn’t turn on? I replaced the cmos battery and thought that would fix that beeping sound.
Landon Elliott - 답글
You may want yo start with reseating your ram or replacing it
Juan Lopez -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 19
전체 시간: 2,599
