주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Chromebook 14-x013dx Battery Replacement
필요한 것
  1. HP Chromebook  14-x013dx Battery Replacement, Keyboard, Touchpad: 1 단계, 이미지 2개 중 1개 HP Chromebook  14-x013dx Battery Replacement, Keyboard, Touchpad: 1 단계, 이미지 2개 중 2개
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook  14-x013dx Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook  14-x013dx Battery Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook  14-x013dx Battery Replacement: 3 단계, 이미지 2개 중 2개
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook  14-x013dx Battery Replacement: 4 단계, 이미지 2개 중 1개 HP Chromebook  14-x013dx Battery Replacement: 4 단계, 이미지 2개 중 2개
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook  14-x013dx Battery Replacement: 5 단계, 이미지 3개 중 1개 HP Chromebook  14-x013dx Battery Replacement: 5 단계, 이미지 3개 중 2개 HP Chromebook  14-x013dx Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook  14-x013dx Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 HP Chromebook  14-x013dx Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook  14-x013dx Battery Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook  14-x013dx Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook  14-x013dx Battery Replacement: 8 단계, 이미지 2개 중 1개 HP Chromebook  14-x013dx Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook  14-x013dx Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the battery out of the laptop case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
NHerbert
회원 가입일: 09/28/17
602 평판
안내서 5개를 작성함
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 회원
USFT-NANCE-F17S3G6
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 55
전체 시간: 3,287
