주요 콘텐츠로 건너뛰기
HP Chromebook 11 G3 Keyboard Mount Replacement
필요한 것
  1. HP Chromebook 11 G3 Keyboard Mount Replacement, Keyboard Mount: 1 단계, 이미지 2개 중 1개 HP Chromebook 11 G3 Keyboard Mount Replacement, Keyboard Mount: 1 단계, 이미지 2개 중 2개
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Keyboard Mount Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11 G3 Keyboard Mount Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Keyboard Mount Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Keyboard Mount Replacement: 4 단계, 이미지 3개 중 1개 HP Chromebook 11 G3 Keyboard Mount Replacement: 4 단계, 이미지 3개 중 2개 HP Chromebook 11 G3 Keyboard Mount Replacement: 4 단계, 이미지 3개 중 3개
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Keyboard Mount Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the keyboard mount out of the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rahul Goyal
회원 가입일: 04/26/17
1,401 평판
안내서 10개를 작성함
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G3
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 20
전체 시간: 567
