주요 콘텐츠로 건너뛰기
HP Chromebook 11 G3 Keyboard Replacement
필요한 것
  1. HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: 1 단계, 이미지 1/2 HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: 1 단계, 이미지 2/2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Keyboard Replacement: 2 단계, 이미지 1/2 HP Chromebook 11 G3 Keyboard Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Keyboard Replacement: 3 단계, 이미지 1/1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Keyboard Replacement: 4 단계, 이미지 1/3 HP Chromebook 11 G3 Keyboard Replacement: 4 단계, 이미지 2/3 HP Chromebook 11 G3 Keyboard Replacement: 4 단계, 이미지 3/3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Keyboard Replacement: 5 단계, 이미지 1/1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Keyboard Replacement, Keyboard: 6 단계, 이미지 1/2 HP Chromebook 11 G3 Keyboard Replacement, Keyboard: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Flip the keyboard mount upside-down.
    • Using tweezers, peel off the two pieces of copper tape that keep the keyboard’s metal cover attached to the keyboard mount.
  7. HP Chromebook 11 G3 Keyboard Replacement: 7 단계, 이미지 1/1
    • Using tweezers, pull back the three metallic-colored pieces of tape near the top left corner of the keyboard mount.
  8. HP Chromebook 11 G3 Keyboard Replacement: 8 단계, 이미지 1/2 HP Chromebook 11 G3 Keyboard Replacement: 8 단계, 이미지 2/2
    • Remove the two 4 mm Phillips #00 screws located on either side of the horizontal black fastener located directly above the touchpad.
    • Lift the horizontal black fastener.
  9. HP Chromebook 11 G3 Keyboard Replacement: 9 단계, 이미지 1/3 HP Chromebook 11 G3 Keyboard Replacement: 9 단계, 이미지 2/3 HP Chromebook 11 G3 Keyboard Replacement: 9 단계, 이미지 3/3
    • Use a plastic opening tool to pry the edges of the metal cover.
    • Loosen the adhesive around the perimeter of the metal cover.
    • The adhesive can be difficult to remove. Use tweezers on any troubling sections. After removing the adhesive, take off the keyboard’s metal cover.
    • If the cover doesn’t come off, repeat prying around the edges with a plastic opening tool.
    • Lift the metal cover.
    • Apply adhesive during reassembly to fasten the metal cover onto the keyboard mount.
    • If only certain keys need replacement, stop here. Instead, use tweezers to remove individual keys by loosening their four snap-on clips from the metal backing.
  10. HP Chromebook 11 G3 Keyboard Replacement: 10 단계, 이미지 1/2 HP Chromebook 11 G3 Keyboard Replacement: 10 단계, 이미지 2/2
    • Use a plastic opening tool to disconnect the keyboard from the keyboard mount by prying along the keyboard’s perimeter.
    • Lots of adhesive attaches the keyboard to the keyboard mount. Loud snapping noises and gray, circular plastic debris are common during adhesive removal.
    • After removing enough adhesive, remove the keyboard’s backing.
    • Apply adhesive during reassembly to fasten the keyboard and its metal backing onto the keyboard mount.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Rahul Goyal
회원 가입일: 04/26/17
1,369 평판
안내서 10개 작성하였습니다
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G3
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Is it possible to get a keyboard that lights up for the HP Chromebook 11 G3? If so then how?
Vanessa Nations - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 2,166
