주요 콘텐츠로 건너뛰기
HP Chromebook 11 G3 Touchpad Replacement
필요한 것
  1. HP Chromebook 11 G3 Touchpad Replacement, Keyboard Mount: 1 단계, 이미지 1/2 HP Chromebook 11 G3 Touchpad Replacement, Keyboard Mount: 1 단계, 이미지 2/2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Touchpad Replacement: 2 단계, 이미지 1/2 HP Chromebook 11 G3 Touchpad Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Touchpad Replacement: 3 단계, 이미지 1/1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Touchpad Replacement: 4 단계, 이미지 1/3 HP Chromebook 11 G3 Touchpad Replacement: 4 단계, 이미지 2/3 HP Chromebook 11 G3 Touchpad Replacement: 4 단계, 이미지 3/3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Touchpad Replacement: 5 단계, 이미지 1/1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Touchpad Replacement, Touchpad: 6 단계, 이미지 1/3 HP Chromebook 11 G3 Touchpad Replacement, Touchpad: 6 단계, 이미지 2/3 HP Chromebook 11 G3 Touchpad Replacement, Touchpad: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Flip the keyboard mount upside down.
    • Use tweezers to lift the tape on the bottom of the touchpad to expose the connector.
    • With a spudger, push up the ZIF retaining flip.
    • Pull out the small ribbon cable.
  7. HP Chromebook 11 G3 Touchpad Replacement: 7 단계, 이미지 1/2 HP Chromebook 11 G3 Touchpad Replacement: 7 단계, 이미지 2/2
    • Remove the two Phillips #00 2mm screws that secure the touchpad to the black plastic housing.
    • Flip the keyboard mount to the upright position.
    • From beneath, push the touchpad up through the top of the keyboard mount to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Rahul Goyal
회원 가입일: 04/26/17
1,369 평판
안내서 10개 작성하였습니다
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G3
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,385
