주요 콘텐츠로 건너뛰기
HP Chromebook 11 G4 Battery Replacement
필요한 것
  1. HP Chromebook 11 G4 Battery Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Battery Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Battery Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Battery Replacement: 7 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 Battery Replacement: 7 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 Battery Replacement, Battery: 9 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Battery Replacement, Battery: 9 단계, 이미지 2개 중 2개
    • Remove the six 4mm Phillips #1 screws.
  10. HP Chromebook 11 G4 Battery Replacement: 10 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the bundled power cable by grasping both edges with your fingers and pulling.
  11. HP Chromebook 11 G4 Battery Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the battery out of the laptop.
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Christopher Flood
회원 가입일: 04/26/17
611 평판
안내서 1개를 작성함
Cal Poly, Team S23-G5, Livingston Spring 2017 Cal Poly, Team S23-G5, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G5
3 회원들
안내서 6개를 작성함
댓글 7개
wow so this is what computer technicians do.
88 88 - 답글
Christopher, your step by step is superb! I am one grateful chicky. Thanks to your guide, I didn't have to replace my laptop! It worked like a charm, despite not owning a spudger. I had to improvise and used a butter knife for tha unclipping of keyboard and my fingernails to unclip tha component clips and didn't even damage my rubber pads! Thank you so very much!!!
Jammie Brasher - 답글
Video was great. Disassembly and assembly took about 1 hour
Jorge De Joya - 답글
Measured power supply voltage as 6V. Not sure if this is enough to bring down the computer. Spec says is should be 7.7Vdc.
Jorge De Joya - 답글
Excellent! So easy to follow! Thank you for the well written guide and tips.
Martha Webb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 80
전체 시간: 63,032
