주요 콘텐츠로 건너뛰기
HP Chromebook 11 G4 Keyboard Replacement
필요한 것
  1. HP Chromebook 11 G4 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Keyboard Replacement: 2 단계, 이미지 1/2 HP Chromebook 11 G4 Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Keyboard Replacement: 3 단계, 이미지 1/2 HP Chromebook 11 G4 Keyboard Replacement: 3 단계, 이미지 2/2
    • Remove the eleven 6mm Phillips #1 screws.
    really good instructions by the way you should probably sponsor mr smedbergs kalsonger
    Halleluja Yacob - 답글
  4. HP Chromebook 11 G4 Keyboard Replacement: 4 단계, 이미지 1/1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Keyboard Replacement: 5 단계, 이미지 1/2 HP Chromebook 11 G4 Keyboard Replacement: 5 단계, 이미지 2/2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Keyboard Replacement: 6 단계, 이미지 1/1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
    thanks — instyrtuctions clear enough for me to adapt to my Chromebook HP 11” wityh different batytery shape -0- battery was dead but uit worked when plugged in - so I have a battery on order - thanks to all!
    alan - 답글
  7. HP Chromebook 11 G4 Keyboard Replacement: 7 단계, 이미지 1/3 HP Chromebook 11 G4 Keyboard Replacement: 7 단계, 이미지 2/3 HP Chromebook 11 G4 Keyboard Replacement: 7 단계, 이미지 3/3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Keyboard Replacement: 8 단계, 이미지 1/1
    • Remove the keyboard assembly by lifting it off the laptop base.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jair Herrera
회원 가입일: 04/26/17
694 평판
안내서 4개 작성하였습니다
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G5
5 회원들
안내서 15개 작성하였습니다
댓글 3개
How do you remove the keyboard from the assembly though? And I wish there was a mention of the fact that the heat sink is attached to the keyboard assembly.
Kyle B - 답글
Same question as the person above. I need to remove the keyboard from the assembly.
Stephen Mason - 답글
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
Nacho Biniz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 9,137
