이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will walk you through the replacement process of a defective or broken keyboard on your HP Chromebook 11 G4. Removing the keyboard is also the basic step to accessing all of the other internal components.
필요한 것
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Same question as the person above. I need to remove the keyboard from the assembly.
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
