주요 콘텐츠로 건너뛰기
HP Chromebook 11 G4 LCD Replacement
필요한 것
  1. HP Chromebook 11 G4 LCD Replacement, LCD: 1 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 LCD Replacement, LCD: 1 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 LCD Replacement, LCD: 1 단계, 이미지 3개 중 3개
    • Open the laptop.
    • With the plastic spudger or your fingers, gently peel off the two thin adhesive layers at the left and right bottom edges of the screen.
    • Do not pry up the plastic bezel (monitor frame), just the adhesive layer.
    • If the adhesive layer isn't coming off, use a metal spudger.
  2. HP Chromebook 11 G4 LCD Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 LCD Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 3 mm Phillips #00 screws located underneath the adhesive layers that were removed in the previous step
  3. HP Chromebook 11 G4 LCD Replacement: 3 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 LCD Replacement: 3 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 LCD Replacement: 3 단계, 이미지 3개 중 3개
    • Gently pry up the plastic bezel with the small, narrow end of the metal spudger.
    • Insert the long, flat end of the metal spudger into the gap.
    • Slide the metal spudger along the edge to disconnect the bezel from the laptop
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, it's okay to use more force.
  4. HP Chromebook 11 G4 LCD Replacement: 4 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 LCD Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the laptop screen as far back as possible
    • Hold the bezel with both hands, then pull the bezel towards you to disconnect the bottom edge of the bezel from the laptop.
    • You may have to use extra force for this step
  5. HP Chromebook 11 G4 LCD Replacement: 5 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 LCD Replacement: 5 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the four silver 4 mm Phillips #0 screws at the bottom of the LCD.
    • Remove the four black 3 mm Phillips #00 screws along the perimeter of the LCD.
  6. HP Chromebook 11 G4 LCD Replacement: 6 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 LCD Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the LCD off its mount and gently lay it facedown on the keyboard.
  7. HP Chromebook 11 G4 LCD Replacement: 7 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 LCD Replacement: 7 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 LCD Replacement: 7 단계, 이미지 3개 중 3개
    • Peel off the clear sticker covering the display cable at the base of the LCD.
    • Gently pull the display cable from the connector.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jonah Silva
회원 가입일: 04/26/17
815 평판
안내서 1개를 작성함
Cal Poly, Team S23-G5, Livingston Spring 2017 Cal Poly, Team S23-G5, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G5
3 회원들
안내서 6개를 작성함
3가이드 댓글
Thanks for the great guidance. Easy as pie!
lcowsert - 답글
i need to replace the top cover of this Laptop HP Chromebook 11-2201NA Can you help
grahamcoles - 답글
I did it! Thank you for terrific instructions.
Krenee - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 40
전체 시간: 8,289
