주요 콘텐츠로 건너뛰기
HP Chromebook 11 G4 Motherboard Replacement
필요한 것
  1. HP Chromebook 11 G4 Motherboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Remove the cable at the top left of the motherboard by grabbing the male connector and applying force in the direction of the wires away from the motherboard.
    • Do not pull on the wires to apply more force. Instead, gently wiggle the connector until it slides out.
  10. HP Chromebook 11 G4 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the battery wires from the motherboard by applying pressure on the male connector away from the motherboard.
  11. HP Chromebook 11 G4 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the wire bundle on the bottom right of the motherboard by pulling the black male connector away from its socket on the motherboard.
  12. HP Chromebook 11 G4 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Use a fingernail or a spudger to flip up the black tab on the zero insertion force connector located at the top of the motherboard.
    • Remove the cable by pulling away from the motherboard.
  13. HP Chromebook 11 G4 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Use a fingernail or a spudger to flip up the white tab on the zero insertion force connector on the bottom left of the motherboard.
  14. HP Chromebook 11 G4 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the 4 mm Phillips #1 screw on the Wi-Fi card.
  15. HP Chromebook 11 G4 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Slide the Wi-Fi card away from the motherboard.
  16. HP Chromebook 11 G4 Motherboard Replacement: 16 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the five 4 mm Phillips #1 screws from the motherboard.
    • One of these screws is black, the rest are silver.
  17. HP Chromebook 11 G4 Motherboard Replacement: 17 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 Motherboard Replacement: 17 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Lift the left edge up and away from the base of the laptop.
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jair Herrera
회원 가입일: 04/26/17
694 평판
안내서 4개를 작성함
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G5
5 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 38
전체 시간: 4,071
