이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
Pry off the rubber pads to reveal a screw under each pad.
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
Slide the spudger along the gap, applying downward pressure to separate the two components.
Lift the bottom of the keyboard assembly to reveal the internal components of the device.
Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
Remove the cable at the top left of the motherboard by grabbing the male connector and applying force in the direction of the wires away from the motherboard.
Disconnect the battery wires from the motherboard by applying pressure on the male connector away from the motherboard.
Disconnect the wire bundle on the bottom right of the motherboard by pulling the black male connector away from its socket on the motherboard.
Use a fingernail or a spudger to flip up the black tab on the zero insertion force connector located at the top of the motherboard.
Remove the cable by pulling away from the motherboard.
Use a fingernail or a spudger to flip up the white tab on the zero insertion force connector on the bottom left of the motherboard.
Lift the left edge up and away from the base of the laptop.
Remove the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
