주요 콘텐츠로 건너뛰기
HP Chromebook 11 G4 Wi-Fi Card Replacement
필요한 것
  1. HP Chromebook 11 G4 Wi-Fi Card Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Wi-Fi Card Replacement: 4 단계, 이미지 1개 중 1개
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Wi-Fi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 1개 HP Chromebook 11 G4 Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 2개 HP Chromebook 11 G4 Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 3개
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Wi-Fi Card Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 Wi-Fi Card Replacement, Wi-Fi Card: 9 단계, 이미지 1개 중 1개
    • Remove the 4 mm Phillips #1 screw.
  10. HP Chromebook 11 G4 Wi-Fi Card Replacement: 10 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Wi-Fi Card Replacement: 10 단계, 이미지 2개 중 2개
    • Gently slide out the Wi-Fi card away from the motherboard by gripping the edges with your thumb and index finger.
  11. HP Chromebook 11 G4 Wi-Fi Card Replacement: 11 단계, 이미지 2개 중 1개 HP Chromebook 11 G4 Wi-Fi Card Replacement: 11 단계, 이미지 2개 중 2개
    • Pop off the white and black wires.
    • The white and black wires have numbered tags on them. These numbers correspond to the numbers on the connection point of the Wi-Fi Card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jair Herrera
회원 가입일: 04/26/17
694 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 2,090
