소개
This is a replacement guide for the HP Chromebook 11 G5 battery. The main purpose of the steps below is to show you how to replace the internal battery. If these steps are followed carefully and correctly the battery should be replaced easily.
필요한 것
Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
Remove the two wires from the top of the WLAN module by pulling them gently with a spudger or your hand and snapping the wires out of place.
다른 4명이 해당 안내서를 완성하였습니다.
