주요 콘텐츠로 건너뛰기
HP Chromebook 11 G5 Keyboard Replacement
필요한 것
  1. HP Chromebook 11 G5 Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Gently remove the keyboard assembly by hand from the base of the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Salma Zitoun
회원 가입일: 01/14/20
385 평판
안내서 2개를 작성함
York University, Team S1-G3, Woodhouse Winter 2020 York University, Team S1-G3, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 1,171
