주요 콘텐츠로 건너뛰기
HP Chromebook 11 G5 Motherboard Replacement
필요한 것
  1. HP Chromebook 11 G5 Motherboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 Motherboard Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
    • Remove the 4mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
  10. HP Chromebook 11 G5 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two wires from the top of the Wi-Fi card by gently pushing them away from the sockets they are connected to using the pointed end of a spudger.
    • The Wi-Fi card can now be removed from the base of the device by hand.
  11. HP Chromebook 11 G5 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Release the ribbon cable connecting the motherboard to the Hall effect sensor by lifting the plastic connector lid using the pointed end of a spudger.
    • You can now remove the ribbon cable from the motherboard by gently pulling it with your hand.
    • Handle ribbon cables carefully as they are fragile and easily torn.
  12. HP Chromebook 11 G5 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 HP Chromebook 11 G5 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the battery connector by pushing both ends away from the motherboard one at a time using the pointed end of a spudger.
  13. HP Chromebook 11 G5 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Disconnect the right-side speaker by pushing both ends of the connector away from the motherboard one at a time using the pointed end of a spudger.
    • This may require force.
  14. HP Chromebook 11 G5 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP Chromebook 11 G5 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Peel the tape over the display cable before lifting the plastic connector lid holding it in place by using the pointed end of a spudger.
    • Remove the cable by gently pulling it with your hand.
  15. HP Chromebook 11 G5 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 HP Chromebook 11 G5 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Peel the tape over the camera connector before lifting the plastic connector lid holding it in place by using the pointed end of a spudger.
  16. HP Chromebook 11 G5 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the charging port connector by pulling both ends away from the motherboard using your fingers.
    • This can be done by using the pointed end of a spudger if you are not comfortable using your fingers.
  17. HP Chromebook 11 G5 Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the five 4mm screws from the motherboard using a Phillips #00 screwdriver.
    • The screw beside the battery is black, while the rest are silver.
  18. HP Chromebook 11 G5 Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Gently remove the motherboard by hand from the base of the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jaspal Kang
회원 가입일: 01/14/20
343 평판
안내서 1개를 작성함
York University, Team S1-G3, Woodhouse Winter 2020 York University, Team S1-G3, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G3
3 회원들
안내서 5개를 작성함
2가이드 댓글
Why is this labeled as difficult? I just did this on my own, and the only somewhat hard thing was reconnecting the keyboard/trackpad back to the motherboard after I was done. Some one should change it to intermediate at the least.
Deegan Monette (_evershade_) - 답글
Do you know if there a tpm ic pad on the board or a tpm header?
Shogun Eliot Billings - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 29
전체 시간: 1,950
